Restoring Old Deck Using Old Joists - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 09:02 AM   #1
Restoring old deck using old Joists
I have a relly old treated pine deck. The surface boards were beyond any restoration, and I have removed them. The rafters underneath are in pretty good shape. There are some signs of aging on the rafters where the cracks were between the surface boards.
To extend the life of the rafters as long as possible, I plan to pressure wash and spray Thompsons water seal on these old rafters.
I am a little bit concerned about the top surface of the rafters - (the exisiting weathering, the nail holes and pry bar marks) and wonder if I should "top coat" the rafters with some flat black exterior paint, or maybe even that "Deck Restore" gritty paint product.
Any thoughts for me on this?
Thank you very much!
AdamsHouseCat is offline   Reply With Quote
Old 02-22-2012, 09:14 AM   #2
Rewards Points: 13,270
Without a picture it's hard to say.
Thompsons comes out time and time again the poorest rated wood treatment in Consumers Digest.
Use Cabots or Olymipc solid stain instead, better yet use a wood preserver.
I've seen where somepeople staple tar paper over the top of the joist to deflect the water away.
(PS there called joist not rafters. Rafters are what's holding up your roof.)
When you install your new boards use ceramic coated screws not nails. Far less likly to pull out and will not rust off.
Old 02-22-2012, 09:47 AM   #3
Civil Engineer
Rewards Points: 4,566
Assuming your joists are in reasonable shape, you should consider installing a waterproof barrier above the joists. This could be Blue Skin (TM) or ice and water shield (that is what I used). For ice and water shield, you cut strips that are about twice as wide as the joist, and the length of the joist, then simply apply it to the top of the joist. I saw this technique in Fine Homebuilding magazine, and others on this site have used it. Said to prolong the life of the joists from 20 years to up to 40 years.
Old 02-22-2012, 10:08 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Flip the joists upside down for a fresh nailing surface.
These "rafters" should be treated lumber if they're not already.
titanoman is offline   Reply With Quote
Old 02-22-2012, 02:28 PM   #5
Rewards Points: 150
Pressure wash using a brightener to kill mold and mildew. Allow to dry then coat with Ready Seal. Do not put any type barrier coating it will collect water on top and rot your new boards from the bottom up.
CaptRandy is offline   Reply With Quote
Old 02-22-2012, 03:01 PM   #6
Disabled wood vet
titanoman's Avatar
So will the old holes.
That's also why I said flip them over.
Old 02-22-2012, 04:34 PM   #7
Rewards Points: 150
Hove no problem with flipping, do it often with deck boards as well.
Old 02-23-2012, 08:11 AM   #8
Willing to listen
Rewards Points: 219
Another vote for ice & water or similar like Grace deck protector which just costs a bit more because it's already cut to width. Seals around the screws you drive for the new top boards. I used it and was easy and I think well worth the minimal extra cost on a new deck project.
Done That is offline   Reply With Quote
Old 02-23-2012, 08:17 AM   #9
Too Short? Cut it Again!
Thompson's is total marketing hype and you should not use it on anything. It is a liquid wax based product and you will be lucky to get a season out of it. It does not penetrate wood fiber like a good sealer will. And it is dramatically overpriced for what it is.
Old 10-21-2012, 01:50 AM   #10
Rewards Points: 16
Can anyone point me to a long-term study or any kind of evidence that sealing the tops of joists extends the longevity of joists? Where did the "Said to prolong the life of the joists from 20 years to up to 40 years" figure come from? I've been searching off and on for three days and while a lot of membrane-selling sites and contractors say they sell their customers on adding various "self sealing membranes" above the joists, I can find absolutely no proof that it helps. In fact, the only shred of long-term evidence I've been able to find is one person who said "I've replaced decking on older deck done both way, not sure why but the ones with tar paper or storm and ice shield were more rotted then the ones left exposed."
Now, of course, tar paper isn't necessarily self-sealing, but storm and ice shield should be. More importantly, I take what he said as evidence that if water ever gets under the "water proof" membrane, it will not dry out and rot will be greatly accelerated. So even if the self-sealing membrane works for 5 or even 10 years to keep it dry beneath, if it ever fails then rot is accelerated and the beam will probably not last any longer than if no membrane had been present - it might even fail faster than without a membrane. And it's very hard for me to believe that a membrane is going to completely stop water for 40 years. Those screw holes are going to start letting water pass at some point due to UV exposure, freeze/thaw, shifting boards due to weather/humidity changes/wind/earthquake/whatever, or even if someone removes a screw and drives it back in without hitting the same hole in the membrane (will a membrane hole missing a screw completely self-seal? I doubt it). It seems almost inevitable to me that at some point the membrane will accelerate rot instead of stop it.
Thoughts?
CDragon is offline   Reply With Quote
Wet PT Lumber for Deck jdm001 Carpentry 7 12-20-2011 10:05 PM
Deck Ledger Question Greg D Building & Construction 9 04-08-2010 08:57 AM
Blocking deck joists ovahimba Building & Construction 3 03-02-2010 09:01 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
