Restoring Cast Iron Tub? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-22-2005, 07:28 PM   #1
Question
restoring cast iron tub?
I have an old cat iron tub. The enamel on the bottom is completely worn away. The local hardware stor has an apoxy type paint to restore the tub.
Does any one have experiance with this type of product or other products to restore a tub.
Or should i consider hiering a profesional to do the job
Chris
chrisintroy is offline   Reply With Quote
Old 03-23-2005, 06:23 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You can use epoxy paint, but it will never look as good as a professional refinishing job. Although it can be a bit expensive (hundreds of dollars), this is usually best left to professionals.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 08:22 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
PVC to Cast Iron oakj Plumbing 3 02-04-2007 11:14 AM
How to? Cast Iron Stacks. mjnovak77 Plumbing 9 09-14-2006 08:46 PM
