Residential Automatic DIY Gate - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 10:31 AM   #1
The driveway (15 ft width) to my home's back yard currently has two gates that swing out. I would like to replace the existing gate with something automated.
I'd like to install an automated system myself, but am not sure whether I should use a slide gate system or a double swing system like the mighty mule. Because I live in an in-town neighborhood, I'm thinking that a slide gate is more secure than one of the double swing systems, but I can't really find anything about which is a better choice.
Any thoughts?
lateracer is offline   Reply With Quote
Old 04-17-2013, 11:36 AM   #2
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 157
This Guy made my Gate, if you look through his Albums, you'll find some Ideas:
http://www.mycreativeironworks.com/Site/Welcome.html
Cheers,
Deja-vue is offline   Reply With Quote
Old 04-17-2013, 12:07 PM   #3
Too Short? Cut it Again!
You will have to automate and balance (and keep balanced) both sides of a swinging gate. A rolling gate will have only one mechanism. I am not sure how one will look with the fence you have though.
Security wise, I think it a toss up. Someone wanting in will just hop the fence or charge the gate with a truck bumper in either case? A solid rolling gate might have some strength advantages over a double swing though.
Probably want to think about putting your gate hardware on the inside, by the way. And buy robust hardware heavy enough to hold up for years.
Old 04-17-2013, 12:15 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by lateracer View Post
Any thoughts?
Build an archway at the gate... and then use a roll up overhead door.
Old 04-17-2013, 06:53 PM   #5
Rewards Points: 5,974
For the swing you will need 2 units 1 for each side. a little pricey. For the roller you will need a new gate, 1 piece. For thr swing from the pic are you sure you have room for the swing?
Old 04-18-2013, 10:35 AM   #6
The current gates are in pretty poor condition and need to be completely rebuilt, so a new gate is already going to happen. As such, I'm open to either design (slide or double swing). There is adequate clearance for the gates to swing out without obstructing the road.
I'm all about using burly hardware since this gate will probably see daily use and I'm planning to be in the house for the next 7-10 years. Additionally, we see a lot of rain here and fence boards like to warp, so I'm probably going to get a powder coated steel frame gate with captured wooden boards. Like this:
I've never seen an archway gate with roll up door on a wooden fence...I get the design functionality, but I think a 15ft wide steel roll up would look terrible on my current fence. Is there some way to make a roll up "blend" with a wooden fence?
Old 04-18-2013, 11:59 AM   #7
MarginallyQualified
I get the design functionality...
It does accomplish the goal!!
Do you need that wide an opening?
The height/clearance would be a bigger concern to me.
When I first posted I thought 8or9 feet wide and maybe 10 feet high.
(for a truck or van w/ ladders; not a concrete mixer)
Depending on construction... Only the archway really needs to "blend".
The gate itself can "contrast" and be set back some from the fence line.
Paint can do wonders.
LINK
Old 04-19-2013, 08:55 AM   #8
Household Handyman
Rewards Points: 1,408
You are in the Atlanta area which I am familiar with having two (2) sisters in the Roswell and Norcross areas. I also have a B-I-L who is a developer and have seen some very nice auto gates on homes. From your photo it appears (IMO) that a slide-gate, or "rolling gate" opening toward the home (left side of the posted photo) would be the best choice. IF you located the slide gate on the right side, per the photo, you would have a large gap at the bottom due to the elevation change at the right side. 1) You are limited as to the "swing pattern" of two (2) swing gates into the back yard. You might be into some sort of code violation if you swing them outward towards the driveway in regards to the property line and your city's codes. I have seen slide gates in your area which have a wooden cover matching the homes fencing also. The set-back on these is a bit more then plaing metal gating due to the fencing material(s). In your case-gates that would swing in would also give you a much smaller area for backing you truck into the yard unless you build them to open more than 90 each. A sliding gate would give you more room for this. Just my opinion.
The Following 2 Users Say Thank You to Thurman For This Useful Post:
lateracer (04-22-2013), ToolSeeker (04-19-2013)
Old 04-19-2013, 04:14 PM   #9
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
lateracer,
You have the perfect layout for a sliding gate. It will be safer, cheaper, and easier on future maintenance. Also, you will not have to fight your way around the exposed swing gate obstruction when you drive in or out.
You will need to pour a narrow concrete ribbon to accommodate an even bottom "V" track to slide the gate's wheels over. A single motor on the inside of the fence, and as for the gate, you could install it on the inside or the outside of your wood fence. Your encroachment off the property line would be minimal. Unless you have a neighbor that want to %^&* with you, you'll be fine.
Good luck,
InspectorZo
Any thoughts?
Last edited by Gary in WA; 04-20-2013 at 12:34 AM. Reason: removed web link belongs below signature line.
InspectorZo is offline   Reply With Quote
The Following User Says Thank You to InspectorZo For This Useful Post:
Clarification on cam-lock usage for private residential applications spowell71 Electrical 3 01-29-2013 02:35 AM
AC power gate opener kutsyy General DIY Discussions 3 05-24-2012 01:06 PM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
