Resetting a pocket door (Fell-off Rollers) = Help?
figure out which side of the opening has the latches up in the track that need to be released to release the door from hanging. this is the side that you need to pull the door casing and the door jam from. once you pull the casing and jamb you can unlatch (there should be a pivot type system that usually needs to swing upward to release the door) the door and get it out of the opening. It might be as simple as something in the wall on the floor blocking the door or the sliding door hardware has failed or just needs adjusting. in fact, after you get the top jamb trim off you can also adjust the door to go up or down with a little wrench that fits above the pivot mechanism on the roller assemblies. that would be the first step...
