Replacing A Snowblower Belt - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-03-2007, 12:35 PM   #1
Replacing a Snowblower belt
I have a MTD Snowflite 8hp/24" snowblower (tecumseh motor) that blew an auger belt yesterday. Has anyone replaced belts on a similar unit.
Do I have to take the front off of it to replace the belt? any help would be appreciated.
Niagarafalls is offline   Reply With Quote
Old 12-03-2007, 06:28 PM   #2
joed's Avatar
Rewards Points: 11,992
I own a store brand unit that I beleive was built by MTD. I changed the belst a couple of years ago. It split in front of the rear wheels. I think I took a couple of bolts at the top and loosen the ones at the bottom. Then lay the engine section backwards on the handle.
Old 12-04-2007, 08:33 AM   #3
I actually got MTD to send me an owners manual, and that is exactly what you need to do!
you take the tope bolts out and loosen the bottom ones and the snowblower basically falls apart into 2 sections. take a couple of guide bolts out and you have full access to the belts.
Thanks for the response.
Old 12-04-2007, 06:53 PM   #4
joed's Avatar
While you are in there might as well change both belts. If one still looks good keep it for a spare.
Dryer Belt KB Services Appliances 2 03-07-2008 01:35 PM
Replacing HVAC Thermostats handy man88 Electrical 4 11-19-2007 02:43 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
Replacing a subfloor miami vice 25 Flooring 10 05-01-2007 10:29 PM
Belt Sander? or other type... KUIPORNG Tools 7 04-18-2007 03:51 PM
