Replacing Sink In Corian Vanity Top - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 05:16 PM   #1
replacing sink in corian vanity top
I have a corian vanity top with an integral sink. I want to cut out the oval sink and install a rectangular, drop-in Mexican ceramic sink. Some of the cuts can be made with a circular saw, but not all. (For example, cutting off the sink bowl.) Can I do this with an angle grinder? If so should I use abrasive disk, carbide-tipped wood blade, diamond masonry blade, or something else? Also how about a jigsaw with carbide blade? Unfortunately I don't have any scraps to practice on, so any advice would be appreciated!
(Because of the drop-in sink, precise finish of the cutout is not very important.)
jaybee is offline   Reply With Quote
Old 08-31-2007, 05:46 PM   #2
Make a template for your new sink cut out. You can play with every thing inside.
Circular saw & jig saw should do it. Leave your opening a little full and sand or router to size.
Big Bob is offline   Reply With Quote
Old 09-01-2007, 02:08 PM   #3
remodeling pro
Cuts with regular woodworking blades, a fine tooth carbide circular saw, and a quality jig saw blade will do it.
troubleseeker is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
Attaching Sink to Vanity allen1466 Remodeling 4 06-02-2006 07:55 AM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
Replacing kitchen sink knob? Pikaia Plumbing 4 06-09-2005 09:43 PM
