Replacing Sill Plate Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 09:56 AM   #1
1968 Ranch
Question
Replacing Sill plate Question
Hello
I have a 1968 Built one story ranch no basement, dirt crawlspace.
I need some advice on how to replace a large section of rotten sill plate. I have to lift the floor joist in a sections say 12' to 15 feet to replace with treated wood and a flashing. I have several 3 1/2" x 3 1/2" x 8' boards and 4 barn jacks, If I tie three or four boards together with lag bolts the 12' to 15' in length (just like a compost beam), this would be used to support joists. Then use barn jacks sitting on the footings in the crawl space to lift that section, just enough to hammer in new boards. I would use the compost beam side ways, 3 1/2 thick and ? width. Am I cracked in thinking that this is enough support for the house?
Electromech31 is offline   Reply With Quote
Old 09-16-2008, 10:21 AM   #2
Registered User
Termite's Avatar
I'd focus on doing small sections at a time instead of a composite beam made up of a number of members. A nominal 4x4 will deflect like crazy, and will probably need a strut and a jack under it every 3 or 4 feet to minimize its deflection under load. 12' or longer would be out of the question unless you have enough jacks...Lag bolts won't do anything for you. I'd abandon that idea.
You don't want to lift the house. You want to support it while replacing the old sill plate with the new.
Old 09-16-2008, 11:54 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
You're objective isn't to really lift up the house, only to relieve the load on the existing plate. If you have 4 jacks and you are preparing to replace 12 feet, you should be fine with the jacks on 3 foot centers. Use a pressure treated replacement. If there are any achor bolts into the foundation, you'll have to notch the new plate around them and then tighten the nut back down. I trust that your jacks are screw type jacks.
Old 09-16-2008, 04:26 PM   #4
1968 Ranch
I do plan on replacing with treated wood. I have to lift enough to get the new sill and some type of flashing. I just want to make sure that the 3 1/2 x 3 1/2 bolted together three to four wide would support the joists enough to lift and replace?
Old 09-16-2008, 08:11 PM   #5
Registered User
Termite's Avatar
How far between jacks? Like I said, a 3-1/2" beam will deflect quite a bit...That's why you don't see 3-1/2" beams supporting homes.
Old 09-17-2008, 07:11 AM   #6
With jacks on 3 foot centers, two bolted together should be plenty for a temporary bearing surface. Just make sure your lifting line from the jack through the blocking is perfectly plumb and that the jacks are setting level. You don't want anything kicking out. Kicked jacks will become missiles under that kind of load.
Old 09-17-2008, 09:08 AM   #7
1968 Ranch
thank you for your information.
thekctermite what do you suggest for a beam to support the joists?
I quess Im still uncertien about how to replace a sill that is rotten without lifting?
This is a big job, so I want to be sure of how Im going to do this.
replacing rotten sill plate on brick exterior home S.LaRue Remodeling 11 11-02-2011 08:50 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 03:07 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
