Replacing A Porcelain Toilet Paper Holder - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 10:11 AM   #1
CDH
Rewards Points: 29
Replacing a porcelain toilet paper holder
I'm not sure if this is the right place to ask this, so if not please move it to where it should be,
with that being said the porcelain or ceramic toilet paper holder got broke in my kids bathroom and I am wondering if there is any special trick that I should know in order to get it out of the sheetrock and install a new one,
it is between the wall studs and appears to me to be just being held in place by caulking around the edges of it and the drywall, by that I mean I believe that the drywall probably has a square cut out the size of the holder. Any help or advice would be appreciated as I want it to look as good as possible.
CDH is offline   Reply With Quote
Old 01-15-2012, 10:33 AM   #2
DIY staff
Rewards Points: 7,174
Use a painters tool or stiff putty knife---cut any caulk with a knife--then tap the sharp tool all the way around the outside edges of the old holder--that may pop it loose.
If not smacking it to pieces with sharp light blows from a hammer may be required.
Goggles--gloved and a tarp ---be safe---Post a picture if you can--
Old 01-15-2012, 10:40 AM   #3
Gymschu's Avatar
Rewards Points: 466
Usually they are backbuttered with grout and are held in place like the rest of the tile work. Perhaps someone caulked around it to give it a more finished look or fill in an unsightly gap. I would score the caulking with a utility knife and then see if you could gently pull the TP holder off the wall. Be careful as you don't want to possibly damage the surrounding tiles. If it doesn't pull off with a bit of elbow grease, you may have to use a roto-tool such as a DREMEL with an attached tile cutting blade. Gently cut into the TP holder and see if you can slice it into two pieces and then use a stiff putty knife to pry the pieces out. That would be my approach, but I'm sure others here who are more specialized in tile work can give you some better ideas.
Old 01-15-2012, 10:43 AM   #4
In a little over my head
Rewards Points: 706
Is it surrounded by tile, or drywall?
ratherbefishing is offline   Reply With Quote
Old 01-15-2012, 10:59 AM   #5
DIY staff
TP holders are often set into a 4x6 cut out in the drywall--
Old 01-15-2012, 01:41 PM   #6
CDH
Rewards Points: 29
It is in the drywall, there is no tile around it. I do believe as 1 of you posted that it is unsanded grout and not caulk that it has around it, I will go this week and see if I can find one that looks similar. I measured the one that got broke and it is approx 5"x 6" but I bet that the cutout in the drywall is probably like 1 of you stated a 4"x 6". I appreciate all the help as I am an electrical lineman and am not the best with fit and finish, in my world if it doesn't fit we just hit it with a bigger hammer and I don't want to make an un-sightly mess in my kids bathroom. Thanks' again. Charlie.
Old 01-15-2012, 03:05 PM   #7
Gymschu's Avatar
Rewards Points: 466
CDH, your job will be very easy if it's just embedded in the drywall and surrounded by some grout. It should come out without much effort.
Old 01-17-2012, 02:31 PM   #8
If it's a clean break an you have the pieces, you can use superglue to put it back together.
pyper is offline   Reply With Quote
downstairs toilet now leakiing after replacing upstairs toilet davesj Plumbing 3 12-03-2011 06:03 PM
Labor/material costs for replacing toilet flange SpookyLugBolt Off Topic 0 07-21-2010 10:08 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet paper holder/towel ring Danieheiz Remodeling 4 03-05-2008 11:25 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
