Replacing Old Steel Basement Windows In A Poured Foundation? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 06:58 PM   #1
Replacing old steel basement windows in a poured foundation?
Hi,
I have four steel basement windows that are about 35 years old in a house that I just purchased. I would like to replace them because they are either rotted through or have real bad rust and / or both. I'm pretty sure that I can pull out the old window and cut out the old steel frame but what I'm not sure of is can these be relaced, any suggestions on brands?
bergmw1 is offline   Reply With Quote
Old 03-07-2009, 10:22 PM   #2
Any home center will have replacements. Vinyl and glass block are usually two types in stock. Just make sure you check your size against what's available before you yank them out. If the frames are weak you can probably just pry them out with a decent pry bar. Start at the interior bottom and pry the center up then the top down and work your way around them.
Rivethead is offline   Reply With Quote
Old 03-08-2009, 10:08 AM   #3
Drywall contractor
Rewards Points: 1,070
You may have to frame the opening down (PT lumber) to get the correct fit for an "in stock" window. Or you can get them special ordered to fit your opening, which will take a couple of weeks and cost more.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-08-2009, 05:16 PM   #4
thank you
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 04:35 PM
Replacing 100 yr old windows Minden General DIY Discussions 3 07-11-2006 11:58 AM
Replacing Old Windows pyrogen74 Remodeling 1 02-09-2006 06:53 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
Replacing windows silverado692 General DIY Discussions 3 11-06-2004 09:42 PM
