Replacing Lally Columns - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 03:07 PM   #1
Replacing lally columns
I need to replacing existing lolly columns with cement filled columns. What is the cheapest way to do this and is this something I can do myself.
Christine Daign is offline   Reply With Quote
Old 03-30-2012, 09:32 PM   #2
DIY staff
Rewards Points: 7,174
Not a good do it your self project----the beam will need temporary jack posts on either side of the column to be removed----the concrete floor is then cut open because the column is standing on a footing under the floor---the jack posts are raised enough to remove the old post---a new one is cut and shimmed---bolted--
Then the jac posts are removed and the floor replaced
Replacing lally columns chronar1 Building & Construction 3 03-05-2012 07:55 AM
Replacing lally columns: Help! navi_jen Building & Construction 0 06-25-2010 10:58 AM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 06:51 PM
Do I need to replace my Lally columns? charbroiled Building & Construction 5 09-24-2009 08:29 AM
Replacing a concrete tube lally Bob2468 Building & Construction 5 05-08-2007 08:27 AM
