Replacing A Door Handle/strike Plate On A Metal Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 01:44 PM   #1
replacing a door handle/strike plate on a metal door
I'd like to replace my front exterior door handle. The strike plate to the new door handle is bigger. The door is metal. How to I carve a new area for the new strike plate? Also I'm going to use a different set up for a dead bolt. My current door jam has a big cut out where the old door jam was. Is there a product that I can fit into this large space or should I just replace the jam?
amysmithwilson is offline   Reply With Quote
Old 10-22-2010, 01:47 PM   #2
pictures would def help in this situation.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-22-2010, 01:48 PM   #3
I think you have your terms mixed up here as well. The strike plate goes on the jamb not the door.
Old 10-22-2010, 01:53 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
but to address the underlying question: you may not be able to use the new handle with the larger plate. There is often nothing behind the door edge that would allow you to use a latch with a larger plate. It could entail cutting a larger hole and welding in a backing plate for the plate. Without seeing it, it is hard to say what you might have to do.
on the jamb; do you need a hole to remain for the deadbolt? If so, you would probably have to weld a filler plate in and drill a new hole.
The Following User Says Thank You to nap For This Useful Post:
amysmithwilson (10-22-2010)
Old 10-22-2010, 01:54 PM   #5
metal doo
You're right...my strike plate for the door knob fits fine on the wood door jam. But, I need to cut out the area for the new latch bolt.
Old 10-22-2010, 01:59 PM   #6
nap
You talking to me?
nap's Avatar
there is a good possibility this is going to be a lot of work. When steel jambs are made, they weld a backer that overhangs the opening for the plate to screw to. If you need to cut bigger than that backer, you will have to weld in a new backer piece. Also, cutting just the surface of the door jamb and not cutting the backer is very difficult.
can you post pics? It would help a lot.
Old 10-22-2010, 03:41 PM   #7
got it!
I got lucky...there was only a small layer of steel on the front and back of the door, as well as the sides. I used a dremel tool to cut out the steel and then was able to cut into the wood! TGIF!
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Removing and replacing door threshold KateMarie Carpentry 8 11-23-2008 01:58 PM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-21-2008 11:10 PM
Sill plate and pre-hung door sithappens Building & Construction 4 01-27-2008 06:18 AM
