Replacing Deck Post On Footing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rander101
Old 09-08-2016, 11:56 AM   #1
Rewards Points: 98
Replacing Deck Post on Footing
So I've got a deck post just dangling there (hard to tell in pic). I've picked up a new post, and do I need to jack up the deck or can I "force" in a new, slightly longer piece? Thanks!
arminius is offline   Reply With Quote
Old 09-08-2016, 01:03 PM   #2
Rewards Points: 13,300
Re: Replacing Deck Post on Footing
Hard to tell much from that picture with all the stuff still around the bottom of it.
Is it sitting on a proper footing as it should be with a post base, or just buried in the ground?
Old 09-08-2016, 01:04 PM   #3
Rewards Points: 98
On concrete
Old 09-08-2016, 01:17 PM   #4
Rewards Points: 48
The quick and dirty answer is to jack the deck up level add about 1/2 " more and slide a new post in, center it on the footing then lower the deck onto it. If you drive a new one in without lifting the deck you will batter the lower end and may have a hard time getting it aligned and leveled correctly.
From your picture it looks like the top of the footing is at or below ground level and that the end of the post has rotted off. If you don't correct that your new post will rot off in a few years too. The better solution is to put some temporary supports in the area of the old post and remove it. Do whatever is necessary to get the top of the footing several inches above ground and install a new post.
Good luck.
Msradell likes this.
rander101 is offline   Reply With Quote
The Following User Says Thank You to rander101 For This Useful Post:
arminius (09-08-2016)
Tags
deck , footing
Replaceing 6" x 6" post on a settleing pool deck. Queequeg152 Building & Construction 7 08-21-2012 11:29 AM
Deck Post Lighting obxbnd Building & Construction 7 08-09-2012 09:44 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck above a cement patio, footing question for the post Adamisu Building & Construction 1 05-25-2011 07:11 AM
Deck Framing - Beams on top of footing (not enough space for post) Maatoy Building & Construction 18 06-02-2010 09:03 PM
