Replacing Deck - Can I Seal The Wood First? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 04:48 PM   #1
mdawson3k's Avatar
Smile
Replacing Deck - Can I seal the wood first?
We are "attempting" to replace the deck floor and handrail. The structure is fine so we are just replacing the deck boards and handrail.
My question is, I know people generally get the deck done, and then seal the boards. Can you seal the boards first, and then, install the boards onto the deck? i would think that it is easier (better working height) and better seal (more thoroughly applied). Then, after installation, reseal the part where the screws go in and cuts have been made.
Any thoughts? Thank you!
mdawson3k is offline   Reply With Quote
Old 06-26-2011, 04:52 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
as long as the decking is dry enough that is the way to do it
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
thomasjmarino (06-26-2011)
Old 06-27-2011, 11:11 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
That's what I did. I sealed the bottom and the sides of the boards, then mounted them, then sealed the top. Came out really well.
CoconutPete is offline   Reply With Quote
Old 06-27-2011, 11:33 AM   #4
Architect / Carpenter
Nothing says the sealer has to be applied after the decking is installed.
As CoconutPete mentioned, it's also a good way to seal both the top and bottom of the boards. It may take a little longer doing each board individually, but it's probably easier on the back.
While you have the structure exposed, don't forget to seal the joists, beams, and posts.
carpitect is offline   Reply With Quote
Old 06-27-2011, 11:43 AM   #5
A Little Of Everything
Rewards Points: 1,362
Sure, you can do that. But you'll also want to seal the whole thing once it's assembled.
Lots more work, but it may very well be worth the extra effort.
DrHicks is offline   Reply With Quote
Replacing deck? help! little-b Carpentry 13 06-04-2011 10:04 PM
Replacing deck...questions... mgh-pa Building & Construction 8 05-27-2011 08:11 PM
Epoxy or Resin Paints for Outdoor Wood Deck CruiseDivaNJ Painting 21 04-16-2011 05:58 PM
Replacing Entire Deck newuser Building & Construction 3 04-16-2011 12:28 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
