Replacing Corner Windows - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 09:27 PM   #1
Replacing corner windows
Hello. Looking to change a corner window in my 1960s house. Currently there is a 3.5 square post where the two windows meet. The windows are the original aluminum crank open kind (don't know the actual name)
I am looking to replace with impact windows which are heavier and have a thicker frame (3 in.)
I was advised to use a 4 x 4 x .25 inch aluminum square post with clips
* Does that recommendation make sense?
* Might there be other things I should consider?
* Are these posts load bearing?
Any guidance us greatly appreciated!
zapp1846 is offline   Reply With Quote
Old 08-03-2010, 07:16 AM   #2
The corner needs support of some kind, not sure why aluminum was suggested. Since you are installing impact glass, I assume you are in hurricane zone??? If there is a lot of salt air, I would avoid aluminum.
The Following User Says Thank You to Just Bill For This Useful Post:
zapp1846 (08-03-2010)
Old 08-03-2010, 08:55 AM   #3
Not sure if the pics help but all the windows were made of aluminum. I am actually about 1.5 miles from the water. The new windows and square tube are painted white.
Old 08-04-2010, 07:10 AM   #4
Not sure I understand why the existing post has to come out??????? It is a 4x4 post. Don't know why it has to have clips???
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 09:56 AM
Replacing corner windows zapp1846 Building & Construction 7 08-03-2010 04:37 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 01:44 PM
Replacing windows silverado692 General DIY Discussions 3 11-06-2004 10:42 PM
