-   -   Replacing corner windows (http://www.diychatroom.com/f2/replacing-corner-windows-77778/)
zapp1846 08-02-2010 09:27 PM
Hello. Looking to change a corner window in my 1960s house. Currently there is a 3.5 square post where the two windows meet. The windows are the original aluminum crank open kind (don't know the actual name)
I am looking to replace with impact windows which are heavier and have a thicker frame (3 in.)
I was advised to use a 4 x 4 x .25 inch aluminum square post with clips
* Does that recommendation make sense?
* Might there be other things I should consider?
* Are these posts load bearing?
Any guidance us greatly appreciated!
Just Bill 08-03-2010 07:16 AM
The corner needs support of some kind, not sure why aluminum was suggested. Since you are installing impact glass, I assume you are in hurricane zone??? If there is a lot of salt air, I would avoid aluminum.
zapp1846 08-03-2010 08:55 AM
2 Attachment(s)
Not sure if the pics help but all the windows were made of aluminum. I am actually about 1.5 miles from the water. The new windows and square tube are painted white.
Just Bill 08-04-2010 07:10 AM
Not sure I understand why the existing post has to come out??????? It is a 4x4 post. Don't know why it has to have clips???
