Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-09-2009, 09:54 AM   #1
Replacing a chandelier with a recessed light.
There is a chandelier in the main entrance and for my first "task" when we get to the house I want to replace it with a recessed light. This will let me know how hard it is before I tackle the other rooms and it will get rid of the ugly chandelier(we're not fans of them). The space above is an open attic with insulation so I know I have an IC light and the hole looks like it would fit a six inch can without much work which is great too. I haven't checked the electrical since we haven't moved in but I'm guessing it's fine. My one major question is what kind of shroud and light should I get that will provide the same amount of lighting as the chandelier does? Will one can cut it or will I have to have more than one?
Also, am I missing anything, this seems like a pretty simple project.
RyanD is offline   Reply With Quote
Old 04-09-2009, 11:36 AM   #2
Remodeling Contractor
Number of cans will be determined by the size of your table. One will not do. At least two, four small ones will be much better. You will need to patch the hole where this light is now.
Old 04-09-2009, 11:39 AM   #3
This is over stairs not a table. The door is the front door, it's a split level where the right stairs go down and the left go up to where the picture was taken.
Old 04-09-2009, 03:59 PM   #4
Oh.. maybe one commercial light with a larger spread and lamp size. But you still need to patch, since this box is most likely nailed against a joist.
Old 04-09-2009, 04:23 PM   #5
You will need several recessed lights to give you the same lighting as a chandelier. How many will depend on the size of the area you're lighting.
The boxes in the ceiling now for the lights that are there will probably be 4" boxes.
Ron
Can I use recessed light wiring for a regualr light? integrity634 Electrical 1 03-18-2009 07:29 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 11:16 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
Replacing hall light fixtures with recessed lights POMEXCAN Electrical 3 04-16-2008 11:40 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
