Replacing Bathroom Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 07:11 PM   #1
Rewards Points: 79
I would like to replace my noisy bathroom fan with a panasonic or equivalent.
It's a first floor bathroom and I don't have access from above and it looks like the panasonic needs two joists to mount the cross piece to.
My current fan is mounted to one joist so its just supported on one side.
Can anybody recommend a good replacement fan if the panny won't install from below without removing too much of the ceiling.
http://www.ntsupply.com/files/produc...VQ5Install.pdf
RalphPeters is offline   Reply With Quote
Old 03-04-2011, 08:34 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Which fan do you have now? They sell a retrofit kit for the basic NuTone fan for under $30. It takes 10 minutes to install into the existing housing and i think it fits others too. will cut the noise level down by up to 50%
I recently put in this Harbor Breeze fan in our second story bathroom ( attic access) Very quiet and moves a lot more air than our old fan. The wife loves it. I think you could put it in from below fairly easily
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 03-04-2011, 09:39 PM   #3
Rewards Points: 5,336
With the old fan out, there's plenty of room to add blocking between the joists and screw the new housing to the blocking.
Ron
Old 03-04-2011, 09:50 PM   #4
Rewards Points: 292
You may have to open up the ceiling to gaing the access you need. Then replace the missing drywall, tape and finish.
Jim F is offline   Reply With Quote
Old 03-05-2011, 12:44 AM   #5
Rewards Points: 79
Ron
The fan that's there now is an Air King, not sure of the model number. it sits in a housing about 7" x 7" x 5" deep.
I think I can add blocking like Ron said after I pull the old housing out and open up the hole for the larger fan.
The original fan uses a 3" vent so I would need to use an adapter to bring it up to 4 inches.
Old 03-07-2011, 06:22 AM   #6
Every bathroom needs a working exhaust fan. It is an important part of bathroom design. It's really not so difficult; the fan comes out after you unscrew the casing holding it up. Disconnect the wiring, attach the new one and replace in the existing hole in the ceiling. Thanks for sharing.
Blue Heron is offline   Reply With Quote
Replacing bathroom wall tiles Shutterbug7 Carpentry 4 11-08-2010 10:04 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Replacing a few individual tiles in bathroom - chiseled a bit into the drywall Pickngrin Drywall & Plaster 4 12-28-2008 06:40 PM
replacing wallpaper in bathroom knharper Interior Decorating 4 12-18-2008 06:47 AM
replacing all above joists in bathroom reno... Bob the blunder Flooring 2 12-03-2008 08:40 AM
