Go Back   DIY Chatroom Home Improvement Forum > DIY Repair > General DIY Discussions
Old 05-25-2014, 08:26 AM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Share |
Replacing Bath Tub Drain
Might have been silconed/caulked in..... could try a heat gun (I would not use a torch).
I've usually been able to break them loose, but I do remember one that I had to twist apart with needle nose very carefully, trying to maintain the shoe threads..... (I got lucky.. got it out... it was on slab with a CI tub) Dremel scoring (not cutting all way thru) the flange and threads helped...
GOOD LUCK
MTN REMODEL LLC is offline   Reply With Quote
Old 05-31-2014, 12:28 AM   #17
Thanks for all your replies...I went with the Universal NuFit and will pick it up soon from HD. It was only $20 after tax...I hope it works!
gerardswork is offline   Reply With Quote
The Following User Says Thank You to gerardswork For This Useful Post:
oh'mike (05-31-2014)
Replacing bathroom sink - questions about tools, drain pipe metazone Plumbing 7 02-09-2014 09:55 AM
Is there a longer bath tub drain flange? Lined cast iron tub. kokobeans Plumbing 0 11-18-2012 09:56 AM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Replacing Toilet Flange in 1/2 Bath sullijos Plumbing 30 10-11-2011 12:37 PM
Replacing below grade shower drain mgray87 Plumbing 8 07-23-2009 11:44 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
