Replacing A Bath Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 01:56 PM   #1
Replacing a Bath Fan
The bath fan in my master bath isn't adequate to control the moisture in the room. The builders didn't consider CFMs when they installed I guess. I've purchased a replacement and I think I can tackle replacing it myself. This is my very first DIY project!
The instructions indicate I need to use spacers (provided) when mounting the unit to an I-JOIST. What is an I-JOIST and is there a lot of difference from regular joists?
Also - this may be an elementary question, but the fan didn't come with screws...what size should I use? The instructions don't specify...
Thanks!!
wildflower is offline   Reply With Quote
Old 08-07-2011, 02:04 PM   #2
Rewards Points: 558
An I joist is a type of engineered wood support that is often used in place of a traditional wood joist. Use 1/4'' - 3/4'' long sheet metal screws.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
wildflower (08-07-2011)
Old 08-07-2011, 02:06 PM   #3
Should I assume that's what I have in the ceiling?
Thanks!
Old 08-07-2011, 03:17 PM   #4
Rewards Points: 5,336
Thanks!
There's no reason to assume anything. You remove the old fan and look into the hole. There's no real installation variation between wood framing members. You screw the fan box to the wood. It doesn't matter if it's a joist or a truss.
If your case, you might need to install blocking unless you have access above to use the metal runners.
Check the condition of the ductwork and make sure it vents to the exterior.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 07:55 PM
Replacing Price Pfister cartridge bath faucet robwallis Plumbing 2 03-12-2009 10:29 AM
Replacing bath tub bluefitness Plumbing 2 01-26-2009 05:40 AM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
