Replacing 3 Prong Plug - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 11:30 PM   #1
Replacing 3 prong plug
I want to replace the 3 prong plug on a motor (intermittent use, max 10 mins) with 14amp draw but all I have is a used plug with 18AWG wire attached. The wire to the motor is 6 ft long and 14AWG. Since the length of the 18AWG section will only be about 2" will this be a problem?
martik778 is offline   Reply With Quote
Old 01-22-2013, 11:35 PM   #2
Rewards Points: 13,300
Sure will, just go buy a new power tool cord, it will already have a plug on it.
Old 01-23-2013, 06:20 PM   #3
joed's Avatar
Rewards Points: 12,036
Instead of trying to used a molded on plug go buy a proper replacement plug to install on the current cable. Strip the end of the cable and install it under the screws in the plug. Black goes under the gold screw. White goes under the silver screw. Green goes under the green screw.
convert NEMA L14-20 receptical to standard three prong 240 v plug paula_stemer Electrical 2 08-06-2011 03:34 PM
Help converting dryer plug to welder plug. RodBarney Electrical 18 07-22-2011 08:18 PM
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 02:07 PM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 07:44 AM
