Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-03-2010, 09:10 AM   #1
Replace old door knob
Is it possible to install modern door knob in old door that has the old key hole style knob? Or do I have to replace the whole door?
ironridger is offline   Reply With Quote
Old 02-03-2010, 09:16 AM   #2
Xtreme DIY'r
The old keyhole style usually has a squre threaded rod that goes thru & each doorknob screws on
Then secured with a set screw
New sets won't fit this style
I bought old style replacement knob set at HD - glass
Old 02-03-2010, 09:39 AM   #3
sdsester's Avatar
The old ones are kind of cool in my opinion and look better than new ones. Why not think about restoring it?
http://www.albarwilmette.com/
sdsester is offline   Reply With Quote
Old 02-03-2010, 11:02 AM   #4
I just replaced all my 1st floor interior door plates and knobs from here -
http://www.rejuvenation.com/fixshow9...=i22v&new99969[WHAT_FINISH]=RECHOOSETHIS&finishDetail=BA
dkh0331 is offline   Reply With Quote
Old 02-03-2010, 05:02 PM   #5
gravity always wins
If the old ones are mortise style (have been pocketed into the edge of the door), you can cut some blocking to fill in the mortise and redrill the door. You would then need to fill any screw holes, sand and repaint. Or, you can get a modernization kit that includes plates to cover all of the previous holes. Look for a Kwikset KW-214 or KW-215 mod kit. There are two sizes. You would drill the door to accomodate the new lock and mount everything using the mod kit.
http://www.doorlocksdirect.com/214.html
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Replace Rotting Porch Column? Dazed&Confused General Discussion 7 09-30-2008 05:44 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
