Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-15-2008, 04:04 PM   #1
Replace Glass In Metal Frame???
Hello i need advice on how to replace the glass in a metal frame window. Please help, here are picturres of window
http://s304.photobucket.com/albums/nn188/daniel1120/?action=view&current=DSCI0554.jpg
http://s304.photobucket.com/albums/nn188/daniel1120/?action=view&current=DSCI0556.jpg
amarlls is offline   Reply With Quote
Old 07-15-2008, 06:03 PM   #2
If this is a single paned glass in a screw together sash, just measure the opening of the metal as a start. Next slide in a thin nail file or pop stick into the groove the glass sat it. Measure it in two places on each side to see it's the same. Double one side, deduct an 1/8" from the total measurement and add the metal to metal opening size. That will be your glass size.
If this doesn't make sense, call in a glazier to fix it.
Ron
Old 07-15-2008, 06:40 PM   #3
Ok great so thats how to measure what size glass ill need. How do I put the glass into frame? Do i take frame off? Do I take off one side?
Old 07-15-2008, 08:49 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Take the whole frame into someplace like Ace, or Home Depot, and let them do it for you. That way if they break the glass during install, you do not have to pay for a second piece.
Old 07-16-2008, 05:46 PM   #5
If it's a screwed together sash, you unscrew it, take it apart and install the glass. Then reassemble it.
If this sounds obtuse, call someone to fix it.
Ron
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Replacing regular glass with low-e in vinyl frame. Doug Crf Building & Construction 1 10-02-2006 07:31 PM
removing frame to sliding glass door luo2000 General Discussion 1 04-09-2006 09:00 PM
