-   -   replace broken window (http://www.diychatroom.com/f2/replace-broken-window-46076/)
william farrell 06-06-2009 11:30 AM
how do i replace the top, fixed section of a silverline single hung window
wrangler 06-06-2009 04:36 PM
There should be glazing beads either on the inside or out that can be popped out using either a screwdriver or scraper. Becareful to not damage them so that you can reuse them. If you do not already have the replacement sash, you'll need to make exact measurements of the width x height. Taking the IGU out is a little bit harder. It is done best with a deglazing tool which most DIYers don't usually have, but it can be done with a 5-way(scraper).
Have you thought about just having it done professionally? The cost should not be too bad, plus they can do it quicker and easier with the right tools and knowledge.
Wildie 06-07-2009 02:02 PM
How can a single hung window have a 'top' half?
I thought a window that has a top and bottom sash would be called 'double' hung. How about a picture?
Ron6519 06-07-2009 04:49 PM
The top sash is fixed, but the look is of a double hung unit.
Ron
