Repairing Wood Siding Next To A Door Frame... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-16-2008, 02:00 PM   #1
Repairing wood siding next to a door frame...
A friend replaced our leaking entryway door and frame.
Outside, where wood siding touches the door frame, there was water damage. Friend removed damaged wood, then filled in the hole with an expanding yellow foam filler. Then he trimmed down with a knife and covered with a layer of caulking. (a paintable acrylic latex adhesive with silicone) Friend says everything is now sealed tight, no leaks. The foam/caulked spot is not smooth, and is a little concave...does not come out to the level of the wood siding. Not ready to be painted over!
Can I fill it in and smooth it out with putty or spackling, paint over it, and make it look good?
P. S. I am good at interior spackling.
Beth777 is offline   Reply With Quote
Old 07-20-2008, 07:16 AM   #2
HomeAdditionPlus.com
Rewards Points: 29
It sounds like all that is left is for you to replace the removed siding. If the foam is concave, then there should be no problem installing the siding over the repaired area.
Last edited by AtlanticWBConst.; 07-20-2008 at 12:59 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed
mjdonovan is offline   Reply With Quote
Old 07-20-2008, 07:27 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Beth777 View Post
...Can I fill it in and smooth it out with putty or spackling, paint over it, and make it look good?
If you are talking about the exterior area, then exterior spackle, a latex caulk with silicone added, and exterior paint will do the job.
If you are talking about the interior area, then spackle away, use latex caulk and your interior paint choice.
Good Luck.
- Build Well -
Old 07-21-2008, 11:49 PM   #4
Thanks for figuring out what I was talking about...
Sorry my question was confusing.
It's exterior. We will replace the damaged siding later, when we have skilled hands to do the work, as well as come up with matching wood for repair.
In the meantime, the caulked-over yellow foam fix is not pretty. I want to do what I can to make it look nicer, if spackling will stick there, on the caulked area.
Is spackling compound better than wood putty for exterior use? Someone at the store recommended a wood putty, but the instructions on the container caution against using it outdoors, so I wasnt' too sure. Especially since I've never used wood putty before.
Old 07-22-2008, 06:12 AM   #5
I would still suggest using the caulk, then finish it with an interior/exterior grade putty. Example, made by DAP: http://www.dap.com/product_details.aspx?product_id=75
- Build Well -
Old 07-22-2008, 07:50 AM   #6
Is this order?
1. Dap putty
2. seal with caulk
3. paint
Surface right now has yellow foam, then a layer of caulking spread over the foam to seal.
Thanks very much for identifying a good choice for exterior painter's putty.
Old 07-22-2008, 08:03 AM   #7
I would say:
Cut away any loose foam.
Apply a layer of caulking over the foam.
Apply Putty. Allow to dry & Scrape flat.
Apply another smooth coat of putty as needed.
Sand Putty smooth.
Apply finished caulking.
Prime
Paint.
- Build Well -
Old 07-22-2008, 08:56 AM   #8
Thanks for the extra help! All clarified now.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
