Repairing Futon Metal Bars? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 12:47 PM   #1
Repairing Futon metal bars?
This futon has metal framing and metal bars, my 8 year old, broke off one of the bars while jumping on the mattress and another is about to come loose, as far as I can tell, the bars are welded on to the frame but if I have to call a welder to tack or weld back on the brackets I may as well purchase another futon as it may cost the same? Is there any other way I can fix this?
mikehende is offline   Reply With Quote
Old 01-23-2008, 01:18 PM   #2
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Use at you own risk:
2 car batteries, some 1/0 cable, a welding rod and clamp. Connect + to + and - to - on the batteries with battery cables, and connect - to clamp amd + to rod. Clamp to metal frame and weld the piece by touching the rod to the place you want to weld.
Or you could try a torch and some strong solder.
Don't you know kids shouldn't jump on the furniture?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 01-23-2008, 01:23 PM   #3
Rewards Points: 5,336
Drill thru the rod and install a nut, lock washer and a bolt.
Ron
Old 01-23-2008, 01:34 PM   #4
Ron
I don't understand this Ron, the bar does not lap over the frame, the bar is welded on the inside of the frame.
Old 01-23-2008, 01:41 PM   #5
Doesn't the bar rest on the square tubing just before it hits the round tubing where the weld broke?
Ron
Old 01-23-2008, 01:53 PM   #6
It only rests on the square tubing for support, that whole frame moves when the futon is being is being opened or closed and the square tubing is a fixed support between the 2 end posts.
Old 01-23-2008, 01:56 PM   #7
Use a big sheet metal screw and drill it into the big tube opposite the small tube, so it goes into the end of the small tube. It won't hold it tight, but it should provide some support.
NateHanson is offline   Reply With Quote
Old 01-23-2008, 02:55 PM   #8
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
take the rod and beat the child with it LOL you don't know anyone who is into cars or a grease monkey? welders are cheap and easy now days, I have 3, 2 mig and an arc. Are you near Tampa FL?
Kingfisher is offline   Reply With Quote
Old 01-23-2008, 03:09 PM   #9
It looks like welding might be my best option to get it sturdy again, I am in NY, will ask around.
Old 01-24-2008, 09:04 AM   #10
Fixer-'til-broker
Rewards Points: 262
There's always JB Weld and duct tape...
Tapping into existing metal duct Mike_Atlanta HVAC 1 11-30-2007 12:07 AM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 11:42 AM
