Repairing Downpipe (gutter Drain Pipe/downspout) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 11:41 PM   #1
Repairing downpipe (gutter drain pipe/downspout)
The bottom of my aluminium down pipe is dammaged and I thought I could take it off(the whole downpipe) and pop it back out-I cant because the bottom is connected to an agi pipe Do I have to cut out the dammaged bit and if so, how does the existing downpipe fit into the new section when they are the same size?
the noz box is offline   Reply With Quote
Old 01-25-2012, 11:51 PM   #2
Rewards Points: 2,212
pictures may help.
Usually new pipe will come with crimping on one end to make it fit inside.
mae-ling is offline   Reply With Quote
Old 01-26-2012, 01:57 AM   #3
Its basicly a huge dent in the bottom of the downpipe
What about if I drill a hole in the dent,put in a metal screw and pull the dent out with pliers, then put a rivit and sealant in the hole.Do you think that might work??
Old 01-26-2012, 06:04 AM   #4
Residential Roofer
Slyfox's Avatar
Originally Posted by the noz box View Post
It's worth trying, would probably work.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
mae-ling (01-26-2012)
Old 01-26-2012, 06:27 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
+1
Has the potential to be a bit messy finished product but I think that should work fine.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (02-06-2012)
Old 02-04-2012, 07:26 AM   #6
The down pipes purpose is to allow the water from the roof via the down pipe. Unfortunately most houses do not have a gutter guard installed this device stops leaves and debris from entering the down pipe which flows directly to your storm water line; this increases the chance of a blockage in the storm water line.
newmanager12 is offline   Reply With Quote
Old 02-04-2012, 07:33 AM   #7
Rewards Points: 13,690
Go buy a new down spout and replace the whole thing. Around $10.00 and less work also would look beter.
Old 02-06-2012, 04:01 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Originally Posted by Windows on Wash View Post
+1
Exactly. Should be able to pull it out and function fine, but it will still look crinkled up, similar to pulling out a dent on a car.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 06:07 AM
installing gutter drain pipes john442 Landscaping & Lawn Care 2 04-14-2008 10:33 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
