-   -   Repairing downpipe (gutter drain pipe/downspout) (http://www.diychatroom.com/f2/repairing-downpipe-gutter-drain-pipe-downspout-131420/)
the noz box 01-25-2012 11:41 PM
The bottom of my aluminium down pipe is dammaged and I thought I could take it off(the whole downpipe) and pop it back out-I cant because the bottom is connected to an agi pipe Do I have to cut out the dammaged bit and if so, how does the existing downpipe fit into the new section when they are the same size?
mae-ling 01-25-2012 11:51 PM
pictures may help.
Usually new pipe will come with crimping on one end to make it fit inside.
the noz box 01-26-2012 01:57 AM
Its basicly a huge dent in the bottom of the downpipe
What about if I drill a hole in the dent,put in a metal screw and pull the dent out with pliers, then put a rivit and sealant in the hole.Do you think that might work??
Slyfox 01-26-2012 06:04 AM
Originally Posted by the noz box (Post 834991)
It's worth trying, would probably work.
Windows on Wash 01-26-2012 06:27 AM
+1
Has the potential to be a bit messy finished product but I think that should work fine.
newmanager12 02-04-2012 07:26 AM
The down pipes purpose is to allow the water from the roof via the down pipe. Unfortunately most houses do not have a gutter guard installed this device stops leaves and debris from entering the down pipe which flows directly to your storm water line; this increases the chance of a blockage in the storm water line.
joecaption 02-04-2012 07:33 AM
Go buy a new down spout and replace the whole thing. Around $10.00 and less work also would look beter.
HomeSealed 02-06-2012 04:01 PM
Originally Posted by Windows on Wash (Post 835038)
+1
Exactly. Should be able to pull it out and function fine, but it will still look crinkled up, similar to pulling out a dent on a car.
