Repairing downpipe (gutter drain pipe/downspout)
10K views 7 replies 7 participants last post by  HomeSealed
The bottom of my aluminium down pipe is dammaged and I thought I could take it off(the whole downpipe) and pop it back out-I cant because the bottom is connected to an agi pipe Do I have to cut out the dammaged bit and if so, how does the existing downpipe fit into the new section when they are the same size?
#6 ·
The down pipes purpose is to allow the water from the roof via the down pipe. Unfortunately most houses do not have a gutter guard installed this device stops leaves and debris from entering the down pipe which flows directly to your storm water line; this increases the chance of a blockage in the storm water line.
