Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-12-2009, 01:18 AM   #16
cocobolo's Avatar
Repair Top of Rotted Floor Joist
nightsurfer: cool handle BTW.
If I understand you correctly, 50% of your 11' long joists cantilever outside the house.
It appears that you have a slightly different code requirement for cantilevers than we do here.
We are permitted 1/3 of the joist length to cantilever, so in the case of a 12' joist for example, only 4' could be outside.
Are the existing joists pressure treated or not? Doesn't sound like it.
I must wonder if two are gone, how far behind can the others be?
One other point, do you have an exit of some kind going from inside the house directly to the deck? I would guess you likely do.
We have a requirement here that the surface of any adjoining deck must be a nominal 2" below the inside floor. That means that when we cantilever a small deck, we must use a 2 x 10 joist. The top of the outside portion has 2" cut off the top. Thus leaving you a 2 x 8 outside.
I think if I were you to avoid any future problems, and I think I can see them arising, that I would remove the existing deck and use the proper footings and posts with appropriate beam to carry your new p.t. joists.
A deck up in the air is no place to mess with. You will be much happier when it is done right.
cocobolo is offline   Reply With Quote
Old 02-12-2009, 07:30 AM   #17
Contractor
cobracdn's Avatar
Originally Posted by nightsurfer View Post
To clarify, the cantilevered portion of the 2 x 8 Joists go 11 feet through the exterior wall and into the house. 5 1/2 Feet are on the outside of the exterior wall.
Cheers
cobracdn is offline   Reply With Quote
Old 02-12-2009, 06:59 PM   #18
cocobolo's Avatar
That certainly makes more sense.
Old 02-27-2009, 01:11 AM   #19
if available where you are, you would be wise to use a couple pieces of "Paralam", one on each side of the rotted joist. they re very light and incredibly strong and rigid. you don't want to add much more weight to the rotted joist, and be sure to lap it onto solid part of joist at least 4" or more, each way from rotted section
allencd@cox.net is offline   Reply With Quote
Tags
rotted top of floor joist
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Urgent Bathroom Floor Repair tman2009 General Discussion 2 12-07-2008 09:53 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
