Repair Top Of Rotted Floor Joist - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 09:02 PM   #1
Repair Top of Rotted Floor Joist
I have a cantilevered deck 8 ft off the ground. As I was replacing the floor boards I notice that a portion on of the top 1 inch of two of the 11 cantilevered 2 x 8 joists are rotted. Can I cut 1 1/2 inches off the top the 2 x 8s and sister in a 1 1/2 inch piece of new pressure wood using construction adhesive and 2 inch screws to return the 2 x 8s to their full structural strength?
Ray-
nightsurfer is offline   Reply With Quote
Old 02-07-2009, 09:13 PM   #2
Registered User
Termite's Avatar
Not really. Fact is that your joists rotting has significantly lessened their structural integrity and adding a piece of 2x2 in place of the rotted portion is really a 2x2 sitting on a 2x6, which is not structurally equivalent to a 2x8.
My suggestion is to either totally replace the 2x8's that are rotted with new pressure treated 2x8's, or sister new 2x8's against the side of the existing 2x8's. Would either be feasible?
Old 02-07-2009, 09:30 PM   #3
I agree
Is the rotted parts the beams on the cantilevered end?
That would be even worse
Altho stress is on all of the joists
Old 02-07-2009, 09:49 PM   #4
Registered User
Termite's Avatar
Yeah, if the rot is on the cantilevered part that is worse. The top of a cantilevered portion of a joist is in tension, and the full integrity of a cantilevered joist is critical to its performance.
Old 02-08-2009, 12:16 AM   #5
Question
Repair Top Rotted Floor Joist
Thanks for your response. To clarify, the cantilevered portion of the 2 x 8 Joists go 11 feet through the exterior wall and into the house. 5 1/2 Feet are on the outside of the exterior wall. The rot is 12 inches from the exterior wall on 2 joists. The other joists are structurally sound. From the responses so far it appears some are suggesting that I cut off all the cantilevered joists and intstall a ledger board and put up new 2 x 8 joists.
Old 02-08-2009, 12:35 AM   #6
Tom Struble's Avatar
Rewards Points: 2,002
no that is not what is being said.you are being advised to replace the rotten 2x8 the full lenght that the existing ones are.Do not cut the cantileverd joist unless your prepared to install properly sized post on a proper footing you will need a permit for that kind of work
Tom Struble is offline   Reply With Quote
Old 02-08-2009, 12:45 AM   #7
Unhappy
Repair Top of Rotted Joist
Unfortunately since the cantilevered joists go through a brick veneer wall into the house I would have to tear out a ceiling to replace the full length of the affected joists. The building code in my area would require footers, 6 x 6 posts and a permit if I cut off the cantilevered joists.
Old 02-08-2009, 06:26 PM   #8
Usually you just add another joist along side the damaged joist As added suport
Old 02-08-2009, 10:24 PM   #9
Rotted Top of Deck Joist
Thank you to everyone for the prompt and thoughtful replies.
Old 02-09-2009, 07:33 AM   #10
Contractor
cobracdn's Avatar
I would suggest strapping with a new joist along side also, but use a joist hanger on the house side.
Cheers
cobracdn is offline   Reply With Quote
Old 02-09-2009, 09:31 AM   #11
Question
Cheers
Cobracdn: Good Idea. Should I used a ledger lock or bolt to secure the joist hanger?
Old 02-10-2009, 06:56 AM   #12
Contractor
cobracdn's Avatar
Depend on the hangers you can get. Here our most common hangers have small holes in them and we use 2-1/2" or 3 " deck screws.
Cheers
Old 02-10-2009, 10:03 PM   #13
Rotted Tops of Joists
Cheers
Cobracdn . . . Thanks for your advice.
Old 02-11-2009, 07:51 AM   #14
Contractor
cobracdn's Avatar
Your welcome, good luck with the project
Cheers
Old 02-11-2009, 08:05 AM   #15
How much rot is there?
Where is the joist rotted?
bwalley is offline   Reply With Quote
Tags
rotted top of floor joist
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Urgent Bathroom Floor Repair tman2009 General DIY Discussions 2 12-07-2008 08:53 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 06:14 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 08:54 AM
