Repair Of A Piece Of Cultured Stone That Fell Off - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-24-2007, 02:52 PM   #1
Repair of a piece of cultured stone that fell off
My child was holding onto a rock on the fireplace and it came loose. It is cultured stone. How do I repair the stone that broke into 2 pieces and then mount it back onto the fireplace in the same spot? What is the easiest way to scrape away the old mortar to redo the area? Or is there a glue that would work to adhere the stone pieces and mount it back up. The piece is about 9x7 inch Driftstone...Thanks
apprentice is offline   Reply With Quote
Old 11-26-2007, 01:31 PM   #2
Rewards Points: 5,326
You could use a construction adhesive made for masonary. It would work to hold the pieces together and to the wall.
I would check the entire wall for any other issues. A child should not be able to pull off a properly installed cultured stone wall, unless his name is Clarke Kent.
Old 11-26-2007, 02:27 PM   #3
THanks for the info...
Cultured stone? kcrossley2 Building & Construction 11 03-30-2008 03:33 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Cultured stone jlb Building & Construction 2 09-10-2007 08:48 AM
Cultured stone? kcrossley2 Building & Construction 18 12-17-2006 06:41 PM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 08:44 PM
