Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-16-2007, 04:37 PM   #1
Do, undo, then do right
BilHam's Avatar
Repair marble counter
The front reveal piece from my marble bathroom counter came undone, fell and broke into about 5 pieces. I want to glue them back together and rehang the piece. I'll shore up the back with 2 angle irons, then glue the top angle to the inside of the countertop . Q: what glue/grout should I use between the joints on the broken parts, and what to hold the angles ?
BilHam is offline   Reply With Quote
Old 11-16-2007, 06:24 PM   #2
PK.
2-part epoxy to put the things back together and hang them.
PK. is offline   Reply With Quote
Old 11-16-2007, 06:33 PM   #3
I recently had to have a marble counter top repaired.The local company I used was "The Marble Clinic." They blended the colour in a 2 part epoxy;if you have similar type of company in your area you may be able to purchase the glue from them.You have to have a flat area,line the surface with wax paper to prevent it from sticking to the working area.Be organized the epoxy sets up fast. Goodluck Jack
jack clancy is offline   Reply With Quote
Old 11-21-2007, 06:17 AM   #4
2-part epoxy adhesives will do the trick.
good luck!
Kitchen sinks is offline   Reply With Quote
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 06:22 PM
Damaged marble beyond repair? argana General Discussion 4 10-30-2007 10:57 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 01:27 PM
Emergency! Need to cut marble counter top. irlizard Remodeling 5 11-22-2006 10:58 PM
