Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-31-2009, 07:18 PM   #1
Post
Repair of fabricated metal chimney/flue
My 30 year old house has wood around the flue instead of brick. The "wooden chimney" is rotting. The house sits under several oak trees. Can the rotting "wooden chimney" be removed above the roof? I'm not sure the rot is just on the chimney. Rot may have moved down . . . .Should I take apart "chimney" and go from there?
I'm not keen on climbing ladders.
momthang is offline   Reply With Quote
Old 08-31-2009, 09:14 PM   #2
Job like this should be done with scaffolding, not by working off a ladder.
A 'cherry picker' would be another option. Cherry pickers are easy to run and may be rented from industrial rental outlets.
Old 09-01-2009, 09:21 AM   #3
Thanks for the suggestions of scaffolding and cherry pickers. I'll try the scaffolding.
Old 09-01-2009, 01:31 PM   #4
Scaffolding isn't as much fun!
Old 09-01-2009, 05:49 PM   #5
Moderator
If it was one of the houses I built in the late '70's, the framing may go down to the second floor. I attached the chase, of T1-11 plywood to 18' studs on three sides, to get the required clearance over the roof surface with the metal chimney, to the exterior wall siding. Then jacked the whole thing upright, with the Fireplace cantilever floor stopping it from going too far. Then set the roof, built the rake chase wall on the trussed, sheathed roof. Hopefully, only the siding needs replacing....
Be safe, G
Old 09-02-2009, 11:42 PM   #6
The siding on the chimney definately needs repairs. But being just a homeowner, I don't understand some of your terminology. Can you enlighten me.
Old 09-03-2009, 09:23 PM   #7
Moderator
Is the damaged wood plywood, made to look like vertical boards? Where is it damaged?
Be safe, G
Old 09-03-2009, 10:05 PM   #8
No plywood.
The damage is to the cedar siding on the chimney. It's hard to tell exactly how much is rotten. The bottom two boards are practicly gone. On the side all of the pieces have slid off horizontal. The chimney doesn't get much sun, and as wet as it has been, the damage has excelerated. If you need I'll go up there and get some pics.
Old 09-04-2009, 09:14 PM   #9
Moderator
No, I believe you. Cedar has to have wind or sun to dry. Hopefully there is some builder's paper behind it, not osb or plywood. If in an area where it is unseen, I would replace with some cementious horizontal boards. Check behind it for rotten framing material.
Be safe, G
Old 09-05-2009, 01:08 AM   #10
Sounds like a good idea. I think there's builders paper behind it. Maybe the weather will be good and I can get up there to work on it. Have a great holiday.
Tags
wooden chimney repair
Metal Roof Repair Questions bruce3404@hotmail.com Roofing 3 09-17-2008 11:00 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
how to repair metal without welding martin9p2 Building & Construction 3 02-18-2007 11:10 PM
