Originally Posted by Thadius856
Wouldn't it be easier to remove the last 6" of that piece? When you reinstall, you only have to fasten the full sheet without any cutting.
Yes it would be... I do plan to make it so a full sheet fits. I did not trust myself to cut/measure correctly on the first try.
So I left a few inches until I could get the drywall sheet and a better ruler. I still have to cut out the section behind the new hot water heater which is bigger than my old model. Someone will have to help me move that out a bit.
I wanted to compare to the other areas in my kitchen but it looks like the drywall does not touch the floor, it sits just a few inches up, and that gap is covered by the trim? Thats the other reason I had to research and still do have to figure out where exactly where to draw my line for the final cut.
Im using a hand held drwall saw a little bigger than a kitchen knife. I don't own any power tools for this job except a drill.
No worries....I will read the drywall forum before I start. I have never hung drywall. I have done touch ups with mud before I paint, and thats it. I do a good job of that because I'm patient.
Got someone else to fix the wire mess that goes into the wall. He is going to install what looks like a breaker box but its for home internet cables/tv cables etc. Looks nice and sits in the wall cavity and will have access pannel in the garage. Cables run from that through conduit to the crawlspace.
