Repair Of Deadbolt - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 10:45 PM   #1
Rewards Points: 22
repair of deadbolt
This is embarrassing...but I can't decide on the proper way to repair the oval piece of my deadbolt lock. Notice how it is loose.
Does it need to be glued? Was it originally just stuck to the paint? Does something need to be repaired internally to the lock?
Advice will be appreciated.
JP79ST is offline   Reply With Quote
Old 01-02-2009, 12:54 AM   #2
Rewards Points: 2,906
Try taking off the latch plate on the other side of the door and looking for a pair of bolts that hold the deadbolt lock in place. If there are such bolts, tighten them. Make sure the escutcheon shown in the photo is in the right position before tightening those bolts.
Then replace the latch plate.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-02-2009, 01:22 AM   #3
Rewards Points: 22
Thanks, but there are no bolts on the other side to tighten. The latch plate won't directly come off. I guess I'll have to try taking off the latch plate for the deadbolt itself. Here's what the other side looks like.
Old 01-02-2009, 06:06 AM   #4
The latch knob is likely secured with a set screw, then the cover pops off, look for a small screwdriver slot around the perimeter. With that off the screws will be accessible.
Old 01-02-2009, 09:50 AM   #5
Rewards Points: 22
Thanks, that did it. The lock is now repaired.
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 05:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 08:20 PM
