Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-18-2008, 07:26 AM   #1
Default Repair chipped fire surround?
Hi, i recently installed my fire surround, however
doing some other DIY
ended up chipping and denting the surround .
This is the fire surround, its the wood white part
that got damaged.
Any idea how i could repair it?
I assume wood filler might be a trick but what kind of paint?
Many Thanks
Ashey85 is offline   Reply With Quote
Old 11-18-2008, 09:39 AM   #2
Building codes guy, Mod
thekctermite's Avatar
It would be easier to help if we could see the chips or dents. Since it is painted, I'd recommend using Bondo auto body filler. It is a two part compound that you mix up into a paste. It is better than wood filler because it can be shaped at corners, lays flat, and can be sanded. It does smell a little though, so you'll want to open a window when you're sanding it, or use a vacuum close to the work.
As for paint, probably an interior latex enamel. I'd have the paint store add some Floetrol to the paint to make the brush strokes lay down as well.
thekctermite is offline   Reply With Quote
Old 11-19-2008, 09:22 AM   #3
By the question, "but what kind of paint?", It sounds like it came pre painted, otherwise you would just use the paint you used initially.
You might need to contact the manufacturer for a touch up can to make the repair or you'll need to paint the whole unit to match.
Ron
Old 11-19-2008, 09:36 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is it wood, stone, or other ?
- Build Well -
Old 11-19-2008, 01:38 PM   #5
It's wood .. the white surround but the rest is marble ..
iv tried to get in touch with the place i brought it from but they say they can not offer me advise can only sell me another unit :| as they got it from a different supplier.
So their will be no paint matching this?
Many thanks for all replies.
Old 11-19-2008, 01:51 PM   #6
You would contact the manufacturer, not the place you bought it. The information should be on the paperwork that came with the unit.
Ron
Old 11-19-2008, 02:02 PM   #7
Ron
There was no paper work, this was from an independent store not a large retailer.
They basically don't want to provide me with information, but would rather sell me another one.
Iv done some research on the net, and someone mentioned they used something like Farrow & Ball Oil Eggshell. Would you have an opinion on it?
More On This Topic
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for your today on Expert Village. The next step when doing a repair of a small chip is you have to fill the chip with polyester body... Read More »
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for your today on Expert Village. First, thing you need to do is prep for paint. We need to prepare the surface, we need to sand it very... Read More »
Hi, I'm Doug I work with 20 great guys in Saint Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for you today on Expert Village. Now Alex is going to prepare the filler that he has applied for a traditional polyester body filler... Read More »
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for your today on Expert Village. Now Dan is sanding with 800 grits sand paper to remove the last little traces of the repair. He filled... Read More »
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for your today on Expert Village. When you are filling a small chip, you need to use very fine body filler. There is lot of different... Read More »
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 10:38 PM
How to properly prepare for slate fire surround jencastro Flooring 6 09-22-2008 01:39 PM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 07:49 AM
Tub surround shower door issues Zharkov Plumbing 14 07-01-2008 12:52 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 1 01-07-2008 04:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
