Repair Air Pump - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 08:15 PM   #1
sweaty
Rewards Points: 270
Repair Air Pump
I use my bicycle pump to pump up my sons' basketballs, using a needle attachment. One of the boys stepped on it and broke off the needle. The stub is stuck in there and I can't use the pump for anything. How do I get it out?
sweaty is offline   Reply With Quote
Old 06-28-2009, 08:21 PM   #2
An EasyOut? You might have to drill the hole larger so the tool can get a purchase.
Old 06-28-2009, 09:11 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
If you can't get out with Needle nose pliers, then you will have nothing to do, then buy a new bike pump.
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 01:01 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
