Rental Property - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 11:38 AM   #1
Unhappy
rental property
I have recently signed a lease for a year on a small home.
Since taking possession there has been a small leak in the ceiling and a
large crack. The owner cut out a piece in the roof and fixed it.
Another crack has appeared about 3 ' from the original crack. Original crack is increasing in size.
Also, several small cracks in the ceiling, in other parts of the house,
have started to appear. You can now see that there has been extensive
polyfilling, sanding and painting throughout the house. The roof
looks quite ragged around all edges . There is certainly quite a bit of moss on it. ... I live in a small lake community . I am single, female. Should I be concerned? it is quite deserted here in the winter.
Owner will be gone to Mexico.
I have asked about the roof . I was told there is no problems .
djarvis is offline   Reply With Quote
Old 11-01-2013, 11:44 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Not acceptable at all.
The land lord needs to send out a qualified contractor to repair.
The Following 3 Users Say Thank You to jbfan For This Useful Post:
BigJim (11-01-2013), djarvis (11-01-2013), gma2rjc (11-07-2013)
Old 11-01-2013, 12:30 PM   #3
MarginallyQualified
Rewards Points: 2,464
Yes.
Stop "asking".
It's time for pen, paper, envelope, stamp... and certified mail.
Make a xerox copy and mail that to yourself. Don't open it.
In writing... ask for a suitable remedy within a specified time frame.
Two weeks for non habitability issues is a reasonable time...
before contacting the County for Code Inspections.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 11-02-2013, 07:08 AM   #4
custom user
Rewards Points: 150
A lease is a two way contract. If he doesn't fix it, you don't send money. Tell him you'll use the rent money to hire a contractor.
JasperST is offline   Reply With Quote
Old 11-02-2013, 09:29 AM   #5
MarginallyQualified
Originally Posted by JasperST View Post
If he doesn't fix it, you don't send money Tell him you'll use the rent money to hire a contractor.
Really bad advice... only way to hold back rent is through Court order.
Without that the LL can 3day the tenant then evict.
Originally Posted by LandLord
That (whatever) was like it is before you moved in.
If you don't like living here then feel free to go.
The key is communication...
backed up by knowing where the legal lines are drawn.
First verbally... then officially if needed.
Old 11-02-2013, 09:32 AM   #6
custom user
Rewards Points: 150
I would take that deal and get out of the lease rather than endure a leaking ceiling. Here, it takes three months to evict, that's plenty of time to relocate.
Old 11-02-2013, 09:49 AM   #7
An old Tradesmen
Rewards Points: 8,194
Amount of time it takes to evict someone varies across the country.
That is something most people don't want on their credit record. Or to have to put on their future lease applications.
Old 11-02-2013, 10:02 AM   #8
custom user
Rewards Points: 150
Doesn't the landlord need a court judgment in his favor to report the loss?
Old 11-02-2013, 10:05 AM   #9
An old Tradesmen
Very easy to get in areas where evictions take 30 days.
In areas whee evictions take long enough for the person to move before it the eviction order is granted. the credit report of owing the money doesn't help anyone's credit report.
All areas have a proper way for a tenant to with hold rent. And that way should be followed. Just with holding on ones own can lead to problems down the road.
Old 11-02-2013, 10:31 AM   #10
custom user
Rewards Points: 150
Those are good points, the OP should see if she has laws like this in her area:
http://accessevictions.com/landlord-...ir-and-deduct/
I would use that as a last ditch effort though, or at least the threat of it if he is stubborn.
Old 11-02-2013, 11:09 AM   #11
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Evictions can take 90-120 days here. First you have to get a court date, that can take 90 days. Then the judge will give them 30 days to vacate. If they are section 8, it may take longer.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 11-02-2013, 11:43 AM   #12
iminaquagmire's Avatar
Rewards Points: 338
You guys are sometimes so dramatic. She said he fixed the leak. Other than that, you don't know any specifics of the construction or problem. Maybe this is an old house with failing plaster. Maybe its a new house with foundation and settlement issues. Maybe the large crack is a bad tape joint caused by the previous leak. You don't know if its purely cosmetic or the house is ready to collapse. I know that if I was a tenant and went to court over a bad tape joint, things certainly wouldn't my way. As for the roof, you don't know anything about that either. It could be slate, asphalt, tile, rolled, flat, cedar, steel, or something else. Moss does not mean the roof is going to give out immediately. Get some more info before you jump on the lease breaking bandwagon.
iminaquagmire is offline   Reply With Quote
Old 11-02-2013, 02:23 PM   #13
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,638
Sounds to me like the OP said the landlord fixed the symptoms, but not the problem.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 11-04-2013, 09:33 AM   #14
Black mold
I forgot to mention that there is a wall under the windows in
that is bowing out... after being told I was over reacting several times .They came this weekend and pulled off the panelling .
The repair man told me the inside the panelling was covered in black mold.I didn't see it because it disappeared immediately.I did see a fair amount of black mould on the wood inside the wall. He told me there were 2 sizable cracks in the chimney. The window is not fitted properly. He did his best to seal, caulk, insulate. Should I accept this? if the water was
coming down the wall , could it not have gotten under the floor as well?
This house was closed up for a year before I rented it. The first week I was in the place I became really sick.so sick I could not work. I thought
I had the flu... maybe not? Please don't think this place looks like a junk heap, it does not , it was freshly painted , tidy and neat etc.
I pay $1100 / mon with utilities probably $1300 with utilities in winter.
Am I over reacting ? should I move out immediately? will this fix work?
I have paid my rent in full as usual. I would really appreciate any good advice , on how to proceed . Am I safe? Took pictures with cell phone
but don't know how to download yet .. Thanks in advance. Dana
Old 11-04-2013, 09:53 AM   #15
custom user
Rewards Points: 150
The consensus is don't act hastily. However, black mold is no small matter. I don't know what you mean by it disappearing but there are ways to treat it. You are really asking for legal advice and we don't even know what state you are in. You should seek out some legal council if you are really worried about this.
The Following User Says Thank You to JasperST For This Useful Post:
djarvis (11-04-2013)
Painting Rental Property (Exterior) justinramani Painting 3 11-19-2012 06:50 AM
Painting interior of a rental property repairlady Painting 5 08-12-2012 08:17 AM
Dual Dryer Outlets in Rental Property Perry401 Electrical 14 05-07-2011 07:24 PM
A gal who owns rental property debstensland Introductions 3 02-27-2011 12:13 AM
Best HVAC Option For Rental Property Hooch HVAC 6 09-05-2008 12:31 PM
