Renovating Main Bathroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 04:17 PM   #1
Rewards Points: 160
Replacing an ancient blue bathtub.
I can spend $1000 on a 3 piece tub and frame it in
Or I can buy a tub for $300 and then tile the walls...
Now if I tile, I have been told to use cement board and Kerdi membrane - but the membrane is optional
Is cement board and tile going to last and stay sealed?
Thansk!
hellothere123 is offline   Reply With Quote
Old 08-04-2011, 12:33 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
The first thing you need to realize is that cement board, tile, and grout are not waterproof. You will need something to keep water from penetrating the wall. There are several options. Kerdi is one of them.
Buds blog is a good place to start your research.
http://www.diychatroom.com/blogs/con...wer-walls-152/
Old 08-04-2011, 11:22 AM   #3
Rewards Points: 194
I have used Kerdi before and I found it easy to use. Make sure you use unmodified thinset though, it won't adhere very well to the cement backer board otherwise.
For your situation though, is your bathtub a shower and bathtub combination, or is it just a bathtub? I think it would be an overkill to use Kerdi over your cement backer board if your bathtub is just a bathtub without a shower.
loftezy is offline   Reply With Quote
main lug or main breaker kenmore Electrical 14 06-18-2011 11:13 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Renovating basement bathroom???? Oldyota Plumbing 1 01-10-2009 07:51 AM
