Removing Wooden Line Posts From Ground - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-20-2008, 10:23 PM   #1
Removing wooden line posts from ground
Problem: Wife and I have purchased property that has an old-style fence along the property line. We want to remove it. It is 48 high chain link spread over a wooden frame of horizontal 2x4s and vertical 4x4s. The vertical pieces are not set in concrete (I hope).
Question: Is there a practical way of removing these 4x4s? I am a senior and cannot just jerk them out of the ground the way I have seen my son do.
bigolepaul is offline   Reply With Quote
Old 05-20-2008, 11:10 PM   #2
Registered User
Termite's Avatar
Assuming you don't own a tractor?
I have done this by using a level and fulcrum. Use mechanical advantage! I had good luck drilling holes in the posts and hooking a chain to them and using the lever to hook the chain when pulling upward. It was still back-breaking work though!
Old 05-20-2008, 11:17 PM   #3
Underground Techie
sevver's Avatar
I have used a high lift jack to pull posts. Wrap a chain around them, and hook the jack to it and just jack them out.
sevver is offline   Reply With Quote
Old 05-21-2008, 07:20 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Unless you need to reuse the posts, dig a couple of inches below the surface and saw them off.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 11:07 PM
New sewer line, damp ground tripower Plumbing 2 09-28-2007 03:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
