-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Removing wooden line posts from ground (http://www.diychatroom.com/f2/removing-wooden-line-posts-ground-21276/)
bigolepaul 05-20-2008 10:23 PM
Problem: Wife and I have purchased property that has an old-style fence along the property line. We want to remove it. It is 48’ high chain link spread over a wooden frame of horizontal 2”x4”s and vertical 4”x4”s. The vertical pieces are not set in concrete (I hope).
Question: Is there a practical way of removing these 4”x4”s? I am a senior and cannot just jerk them out of the ground the way I have seen my son do.
Termite 05-20-2008 11:10 PM
Assuming you don't own a tractor? :wink:
I have done this by using a level and fulcrum. Use mechanical advantage! I had good luck drilling holes in the posts and hooking a chain to them and using the lever to hook the chain when pulling upward. It was still back-breaking work though!
sevver 05-20-2008 11:17 PM
I have used a high lift jack to pull posts. Wrap a chain around them, and hook the jack to it and just jack them out.
Maintenance 6 05-21-2008 07:20 AM
Unless you need to reuse the posts, dig a couple of inches below the surface and saw them off.
