Removing A Welded Metal Piece--what's The Best Way? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 01:47 PM   #16
Retired from the grind
Rewards Points: 6,652
Originally Posted by kwikfishron View Post
I didn't mention HF because those grinders are junk.
A couple of years ago a friend and I were using grinders to fine tune notches on logs, I had my 7-8 year old Makita he had his brand new $20 HF grinder. He was so thrilled on what a good deal it was.
He got maybe 3 working hours (if that) out of it before burning it up.
He exchanged it and burned that one up too (this was getting funny). Third times a charm??? Not!
Finally he came back Porter-Cable and actually got some work done.
It is a hit or miss on their stuff, along with how you use it. If it is continuous use, any tool can fail due to heat build up on the windings or brushes. QA has gone down a lot on every tool out there, regardless of the name. Also just because the tool is more expensive, does not make it better.
Personally I would have used an air powered tool for doing those notches on the logs, vs. electric powered.
Old 11-07-2013, 02:41 PM   #17
Mold!! Let's kill it!
Rewards Points: 2,012
If you are just going to cut the pockets down flush with the deck, you can use a hacksaw. You might break some blades, but the only burnout will be the operator.
Metal floor vent out of shape Arjun007 HVAC 10 10-28-2011 11:01 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
