Removing A Welded Metal Piece--what's The Best Way? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 09:37 PM   #1
Removing a welded metal piece--what's the best way?
Hi, I'm trying to remove a welded metal piece off the back of my trailer to make room for a loading ramp. What's a good way to do it? Here's a video of the back of the trailer:
http://www.youtube.com/watch?v=KgZ-h...ature=youtu.be
Delta223 is offline   Reply With Quote
Old 11-06-2013, 09:45 PM   #2
Msradell's Avatar
Rewards Points: 172
A side grinder is probably your best bet.
Msradell is offline   Reply With Quote
Old 11-06-2013, 09:49 PM   #3
Rewards Points: 994
The usual procedure is to cut the weld bead but we have no idea what tools you have at your disposal except a hammer.
Old 11-06-2013, 09:55 PM   #4
I have no tools at all actually (not even a hammer); so whatever is cheapest will work.
Old 11-06-2013, 10:30 PM   #5
Rewards Points: 13,458
No tools
How do you do anything with no tools?
A grinder it the right tool to use but pick up some gloves and some goggles while your out.
There's going to be sparks flying everywhere so make sure you do this outside and watch for leaves catching on fire.
Get a tight grip on it because it's going to want to ride up as your grinding.
Also going to need some primer and paint. Any place you grind is going to leave bare metal.
Old 11-06-2013, 10:46 PM   #6
Lord of Slums
Rewards Points: 1,974
Put 2x 4 in the piece and tie a tow chain around it, then get some slack and floor it.
mj12 is offline   Reply With Quote
Old 11-06-2013, 11:07 PM   #7
Rewards Points: 6,652
You are joking. Who does not own one single tool. Give me a angle grinder with a cutting wheel, and those tangs would be gone in a heartbeat.
Personally I would also go with a 2x4 on the end of the ramp, so that it allows the ramp to be held on the trailer by those tangs.
Old 11-07-2013, 01:44 AM   #8
Rewards Points: 994
This may be a DIY forum but you need to pay the guy that put the washer in the trailer to come take it out before you hurt yourself.
Old 11-07-2013, 07:40 AM   #9
joed's Avatar
Rewards Points: 12,440
Old 11-07-2013, 08:16 AM   #10
Rewards Points: 80
Sorry, the images are too dark for me to say for sure, but rather than removing them completely, can't you just cut them off flush with the bed, so that they are out of the way, but can still be used? The rear rack will lose some lateral support with shorter pockets, but that is dealt with by installing brackets on the side and back racks, in order to pin them together in transit. In the absence of tools, run it by a local welding shop, and they'll have plenty of options for shortening or removing them.
Old 11-07-2013, 09:04 AM   #11
As I was sleeping on this I thought about cutting them down as well. I think it'll work. I found a angle grinder on craigslist for $20; it's a drive but I think worth it.
Old 11-07-2013, 09:25 AM   #12
kwikfishron's Avatar
Rewards Points: 412
You can buy new at a box store for about $30.
kwikfishron is online now   Reply With Quote
Old 11-07-2013, 10:54 AM   #13
bbo
or HF for even less
http://www.harborfreight.com/catalog...=angle+grinder
I have one of the heavy duty HF ones. its paid for itself many times over.
if I needed to use one daily I'd get a name brand one, but for your little job, this would do the trick.
bbo is offline   Reply With Quote
Old 11-07-2013, 01:05 PM   #14
Or open box at harbor freight for $19.
Old 11-07-2013, 01:35 PM   #15
Rewards Points: 412
I didn't mention HF because those grinders are junk.
A couple of years ago a friend and I were using grinders to fine tune notches on logs, I had my 7-8 year old Makita he had his brand new $20 HF grinder. He was so thrilled on what a good deal it was.
He got maybe 3 working hours (if that) out of it before burning it up.
He exchanged it and burned that one up too (this was getting funny). Third times a charm??? Not!
Finally he came back Porter-Cable and actually got some work done.
Metal floor vent out of shape Arjun007 HVAC 10 10-28-2011 11:01 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
