Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-07-2009, 03:54 PM   #1
Removing water stains for shower tile grout?
I'm trying to remove some yellowish water stains from shower tile grout. I've tried grout cleaners, abrasive cleaners and bleach (using a toothbrush and scour pad) to the grout and the stains remain. I've just about given up. Anyone offer any suggestions before I throw in the towel?
Thanks.
acyate is offline   Reply With Quote
Old 08-07-2009, 06:18 PM   #2
I just cleaned up a nasty shower with one of those small steam cleaner units - worked very well and easily. Not sure how it would work on your grout problem, but if you could borrow or rent on might be work a try.
Old 08-07-2009, 07:38 PM   #3
Tileguy
Bud Cline's Avatar
Sounds like it could be iron oxide from your water. Test a few spots with a product called "CLR" (Calcium, Lime, Rust). It comes in a gray bottle.
If that doesn't do it my next choice would be pressurized steam.
Marble tile - would rather not use grout epeterson777 Tiling, ceramics, marble 3 05-27-2009 03:47 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
