Removing Tile - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 01:01 AM   #1
removing tile
Hi,
The house I bought has tiles on the wall in the kitchen behind the sink and I want to remove them and have just the regular wall instead. How do I make it look as clean as a regular wall?
(I am pretty new at these home projects)
npqster
npqster is offline   Reply With Quote
Old 02-22-2011, 07:17 AM   #2
That depends on the tile adhesive and how well adhered the tile is. Some may simply pop off with a gentle pry with a screwdriver, some may pull off pieces of drywall. If it was a really good job, you may have to tear out all the drywall. If you are lucky and have the first two, patch over the dings with drywall mud, sand lightly and paint. Wiping carefully with a damp sponge will often smooth out the dry mud and keeps the dust to almost nothing. If you have to replace the drywall, then you have a fresh new pallet.
Old 02-22-2011, 07:27 AM   #3
DIY staff
Rewards Points: 7,174
Bill said that very nicely.--Mike---
Old 02-22-2011, 11:31 AM   #4
more details
thanks but I forgot to mention it's not drywall
it's lath and plaster from this original 1924 San Francisco house
Old 02-23-2011, 06:44 AM   #5
removing tile
Tile is set in thin-set mortar, which dries very hard and is difficult to remove completely and cleanly. Tile is a great floor and wall covering for all areas of the home. If a tile in an installation has broken, you could be risking water damage below the tile. There are many different types of tile removal equipment that work on both ceramic tile and linoleum tile. Broken tiles can also make the entire room look old, or out of date.
Blue Heron is offline   Reply With Quote
Old 02-23-2011, 08:24 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WOW!!!
BH,
The thing to do is to try and pry off a few tiles using a 3-4" putty knife and a hammer and see what you are up against. DON'T use a screwdriver, that could cause needless damage. Not all tile gets installed with thinset mortar. If you are careful you can proably remove the tile with no damage to the substrate. If you should damage the wall it can be fixed easily enough. I doubt you'll be experiencing any water damage, that idea is pretty far-fetched.
Sample a few tiles and get back to us.
XXX
Tags
kitchen , removing , tile , wall
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Removing peel and stick tile adhesive in preparation for tile stubborn1 Flooring 3 01-09-2011 02:34 PM
Removing vinyl tile (at least I think it's some sort of vinyl) natecase13 Flooring 1 07-13-2010 11:55 AM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
