Removing Subfloor Help ! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-25-2005, 03:59 PM   #1
removing subfloor help !
Help ! Does anyone know what tool to use to help remove subfloor under cabinets .The floor runs under them and I don't want to remove them but I have no clue how to get under the space to cut along cabinet base.Thanks
mespunky2 is offline   Reply With Quote
Old 06-27-2005, 05:59 PM   #2
Construction Junkie
Do it right.
The cabinets have to come out because (a) the subfloor is nailed down under there, and (b) you have to nail down the new subfloor.
sharisavage is offline   Reply With Quote
Old 06-27-2005, 07:15 PM   #3
You could try a Rotozip with a right angle attachment.
plumguy is offline   Reply With Quote
Old 06-28-2005, 12:48 AM   #4
The cabinets have to come out before removing the sub-floor.
There are many variables when replacing the sub-floor. The new material my be thinner or thicker then the original sub-flooring, you have to nail down the sub-floor under the cabinets.
CarpenterDon is offline   Reply With Quote
Old 06-28-2005, 04:10 AM   #5
If you are just talking about removing the underlayment up to the vanity, use a toe-kick saw. It is made by Crain. You may be able to rent. Dangerous kick-back, keep a firm grip. You'll have to chisel any inside corners.
If talking the sub-floor, remove the cabinets.
Remodeling is offline   Reply With Quote
Removing a Floor Furnace M.O.I. Flooring 3 10-27-2015 09:02 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 11:53 AM
removing knockdown texture K_I37 Painting 7 05-07-2006 01:23 PM
removing frame to sliding glass door luo2000 General DIY Discussions 1 04-09-2006 08:00 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
