Removing Sliding Screen Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2007, 02:21 PM   #1
Removing sliding screen door
What is the easiest way to remove a sliding screen door? I want to re-screen it but can't get it off the track. I am afraid of bending the frame.
Keyo77 is offline   Reply With Quote
Old 08-18-2007, 04:00 PM   #2
Darylh's Avatar
Thee should be 2 screws on the bottom of the door that are visible, just turn them in the direction that loosens the wheels and off it comes.
Darylh is offline   Reply With Quote
Old 08-18-2007, 06:07 PM   #3
The only screws I see are at the top and on the bottom of the side that slides toward the frame (to shut). There are no other screws visible. I'm gonna give it a shot and see what happens. Stay tuned!
Old 08-18-2007, 06:12 PM   #4
Custom Cabinet Maker
Key; Normally all you need to do is lift the screen UP into the track and the bottom will swing out. If the wheels still snag the track, lift up and slide a stiff putty knife along track and under the wheels. Most are spring loaded.
JackM
skymaster is offline   Reply With Quote
Old 08-18-2007, 07:13 PM   #5
Found all the screws (two were hiding under weatherstripping). The screen door popped right out and away we went! Thanks for all the help guys!
Screen door...Where to get it? eric s General DIY Discussions 6 04-13-2016 07:03 AM
enlarging a screen door bofusmosby Carpentry 9 05-03-2007 03:26 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 12:43 AM
removing frame to sliding glass door luo2000 General DIY Discussions 1 04-09-2006 08:00 PM
