Removing Shed Foundation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 09:23 PM   #1
Removing shed foundation
Hi. I hope you will forgive my ignorance since I am a new homeowner. The place i just bought has a shed foundation on a side yard, but it is not needed since there are already two sheds on the property. The previous owner started the shed project, but never actually built it. I want to remove it to make room for a dog run on the side yard.
It is concrete pillars with metal posts and 2x4 with plywood on top. I was able to remove about half of the screws holding down the plywood, but the rest of the screws are not moving. I am thinking that the next step is to get in there with a prybar and start pulling it apart. I would also need to dig out the cement footers after all the wood is off.
Is this the correct approach?
MelodyS is offline   Reply With Quote
Old 05-28-2012, 10:06 PM   #2
Rewards Points: 2,212
Sometimes you can use a sawzall (reciprocating saw) and circular saw and cut things apart
mae-ling is offline   Reply With Quote
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 01:42 PM
Foundation for 8x10 Vinyl Shed fireberd350 Building & Construction 17 03-04-2012 04:49 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
Leveling skids for a shed on a unlevel concrete foundation will02 Building & Construction 7 01-16-2012 02:58 PM
