Removing Rust Stains From Porcelain Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 10:53 PM   #1
removing rust stains from porcelain tub
I have a porcelain tub that has rust stains - some of them caused by the bottom of cans of shaving cream. Attached are 2 pics of the problem.
I tied Whink 01281 Rust Stain Remover which is highly rated on Amazon - without any luck. Looking for some other advice. Thanks
removing rust stains from porcelain tub-0928011249.jpg   removing rust stains from porcelain tub-0928011249a.jpg
techman41973 is offline   Reply With Quote
Old 09-28-2011, 10:56 PM   #2
Rewards Points: 150
Try a two part epoxy touch up kit.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 11:07 PM   #3
Rewards Points: 558
You can try using vim which is a mild abrasive. Rub it on in a circular direction with a damp cloth.
epson is offline   Reply With Quote
Old 09-29-2011, 04:36 AM   #4
DIY staff
Rewards Points: 7,174
Try 'The Works ' toilet bowl cleaner----works for removing rusty water stains.
Old 09-29-2011, 08:18 AM   #5
Rewards Points: 562
rust out
4just1don is offline   Reply With Quote
Old 09-29-2011, 11:27 AM   #6
Rewards Points: 29
Bon Ami
rjgogo is offline   Reply With Quote
Old 09-30-2011, 08:57 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Muratic acid
PoleCat is offline   Reply With Quote
rust stains in white sinks asiatheboxer Plumbing 4 09-05-2011 01:45 PM
rust stains on my asphalt roof ridpalcak Roofing/Siding 1 07-01-2011 10:49 AM
rust stains from finish nails rocketdoctor Building & Construction 1 05-14-2010 04:16 AM
Rust Stains from Railing on Concrete Walk stubits Building & Construction 2 06-05-2009 06:20 AM
Stains on polished porcelain tiles tommurphy73 General DIY Discussions 4 12-24-2007 01:03 PM
