Removing Post - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 10:03 AM   #1
Rewards Points: 236
removing post
i have 2 posts that i want to remove. they are cemented down, very sturdy. 1 is straight vertical. the other is angled to help support the other.
i am thinking i could weld something onto the post, strong bar perhaps. then using 2 floor jacks to jack it up.
what do you think ?
Fix'n it is offline   Reply With Quote
Old 04-07-2013, 10:19 AM   #2
Rewards Points: 236
ya know. we pulled an engine/trans, 350/350, from a 79 Z-28, yesterday. i wonder if the lift will pull that out. i think i am going to find out.
Old 04-07-2013, 10:41 AM   #3
Rewards Points: 1,312
If they were cemented in the way I concrete posts in, start digging, you'll be time and frustration points ahead . Try just digging about a 190 arc around first to see if it will disrupt the bond enough . For lifting / pulling a clove hitch knot on a slightly rough surface is usually all that's needed .
Old 04-07-2013, 10:51 AM   #4
Rewards Points: 236
idk how they made the hole. i am figuring a post hole digger. i am going to drill a hole and put a rod though it. then wrap a chain.
getting started after breakfast = 1/2hr ish.
Old 04-07-2013, 11:45 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
The way I pull posts up is take a chain and wrap it around the base of the post, get an old tire and rim let a little air out of the tire. Stand the tire against the post, lay the chain across the tire, hook to truck and pull. That should pull the post up and out of the ground.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (04-07-2013)
Old 04-07-2013, 12:07 PM   #6
I have no idea why people ask for advise then do it their own way .
So you can screw around welding , drilling and whatever, or you can set loop "A" on top of loop "B" of a chain , short link preferred , drop it over the post and pull with anything you probably have . For a second stroke if needed , slightly loosen the knot and let the chain slide down the post .
You can see where the chain bites into the tree that was pulled with a 75 HP tractor , and MR. Coyote can't pull it loose so he chews the rope .
But go ahead and do it the difficult way if your frustration level isn't a concern and you have plenty of time .
removing post-clove-hitch.jpg   removing post-wood-stump-pulled-3-6-10.jpg   removing post-game-cam-coyote-pulling-11-28-10.jpg   removing post-game-cam-coyote-rope-chewed-12-17-10.jpg
Old 04-07-2013, 08:14 PM   #7
Rewards Points: 236
posts are out. piece of cake, nearly effortlessly. no welding/drilling.
Post base for wood porch Quercus Building & Construction 2 07-22-2012 02:43 PM
Removing post support/laminate beam? macminn18 Building & Construction 6 10-08-2010 09:42 AM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
